1 - 2 of 2 Posts
Trying to keep family harmony here. 2000 XE with no mods. Brother in laws step daughter rear ended car, no air bag deployment, bumper canted 30 degrees inward. What should I look for to determine if brackets are not bent? Are there a lot of bolts and screws to remove?
Thanks in advance.
It is simple to take off the front bumpers. there are rectangular clips inside the the grille and under the hood. you simply get a screwdriver and twist them to the right and pop off the grille. I cant remember how the lower bumper comes off but there are two pieces to the lower bumper which can all come out together. I know there are two brackets right in the front. They are pretty durable and can be bent to be straight with some force. You can also use a level to make sure they are straight. I thought it was gonna be tough as well but on these ancient machines, they were easy.
1 - 2 of 2 Posts
