1 - 8 of 8 Posts
Hello everyone,
Just found that I have a broken (or previous owner cut it on purpose) wire from the connector F37 or F38, not sure which one. I can't find the full wiring diagrams for that connectors, only found that some of the wires goes to knock sensor and crancshaft position sensor, but what other wires do and especially the broken one?
I believe this is F37 connector, the yellow wire from the bottom right position.
Discussion Starter #4 (Edited)
Go to the FSM and find the EC section for your model year. Under VG33E codes find code P0325. You will find the wire colors and positions for the KS wires on connector F37.
From what I see there it does not appear to have the resistor mod done.
KS connected through the terminals 5 and 6. I had to turn F37 connector lol, sorry guys
75580
Hope it's KS bypass: HOW TO- Knock Sensor Resistor Mod on S/C 1st gens
Discussion Starter #7
Mine is bypassed but it’s been 9 years ago I don’t recall the position the diode is in. I can check in the morning.
Thank you!
Sorry my bad, just realized if you turn the F37 connector to yourself, that "yellow" (looks like xD) wire is the terminal n8. So I hope it's just KS bypass somewhere, will check it.
1 - 8 of 8 Posts
