1 - 8 of 8 Posts
So I got a deal on a 2004 Xterra (free) that had been wrecked with a good motor and I found a deal on a 2001 Xterra (300!) in good condition with a rod knock. Has anyone swapped Motors? 04 motor to an 01. Will they swap? Things that worked, things that didn't work? Everything just a straight swap, or major retrofit?
Nice find man, its a simple swap. Nothing major was changed in the 04, only thing that comes to mind is the egr tube from the upper plenum to the driver header was added so you want to use the 01 plenum. I currently own an 01 se and i had an 04 that i rebuild last year.
Hey fily!
Can you tell me a little more about the EGR tube? I'm in the process of installing headers on my 2004, and the EGR bung is welded at the wrong angle. Does the 2001 EGR have a different configuration, or is it missing altogether?
Hows it going clunker!
I believe the 00-01s didn't come with an egr system, atleast my 01 didnt have one, while the 02-04 does. Thats odd that the bung isnt relatively close to the stock location. Which headers did you pick up? I think i remember reading awhile back about some headers coming with a egr tube that works with the new angle but i may be wrong.
Thanks for the response fily.
The headers were dirt cheap. No brand given, but they are definitely made in China, and the parent company sells products on Amazon under more American-sounding names like DNA Motoring and Auto Dynasty. They were only $138 for the pair, and I'm still doing the write up on them. The bung is welded close to the correct location, but it sits at an angle that is off by at least 10 degrees. Not surprising since I had to redrill the mounting holes and gaskets, one of the O2 sensor bungs requires relocating the transmission dipstick, and only the tubes are stainless steel. The rest is mild steel. That being said, I was on a budget, and the X is back on the road.
I considered doing an EGR delete, but I was worried about losing mileage. If the computer detects too much oxygen it will add more fuel to the mixture. This is what you would expect if the cylinders are filling with 100% air instead of a portion coming from the exhaust. ECU isn't throwing any EGR codes with the temporary delete, so maybe I'll make it permanent. If the early models didn't have it, then I probably don't need it.
1 - 8 of 8 Posts
