What are you guys doing for hooks to remove the engine? Did your engines come with the "slingers" (hooks)? Neither of my Xterras have them. The dealer doesn't sell them anymore, and all online references show the part discontinued.
Some people appear to be using an AC compressor mounting bracket on the driver side (front) and an exhaust manifold bolt on the passenger side (??) to connect the chains to. I was originally planning to pull the motor WITHOUT removing the manifolds or the catalytic convertors, so I wasn't planning to get into the nasty PB Blaster soaking process over several days to break loose all the exhaust bolts (without breaking them).
Is there a way to get the slinger still? If so, do you have to remove the front and rear timing covers to get to the mount on the passenger side head to install the slinger?
Thanks!!
Thanks!!
