Hi,
No I haven't gotten that far.
The belts that are still on are the Alternator and Timing.
I can hear the noise is not coming from the alternator, but from the timing belt area.
Do you recognize the type of noise?
Silver Submarine
Check the 8MM bolt at the very bottom of the timing belt cover. That might have backed out and touching the crank pulley. Also try removing the alt belt and see if the noise is still there.
