My '06 (6sp, off road) has symptoms of bad u-joints. High pitched noise sound when getting going, vibration when stepping on gas at higher speeds. The Haynes manual and everything I've found online shows a u-joint in front and a u-joint in back of the driveshaft. Mine seems to have something else in the back - presumably that's a CV joint? The boot seems to be intact.
Should I just remove those bolts just like if it were 4 bolts and u-joint? Then just replace the front u-joint and hope that fixes the problem? Or am I about to do something stupid and/or waste my time?
Thanks!
Thanks!
