1 - 11 of 11 Posts
Howdy. I have an 04X and am going to put a 2" BL on. My plan was BFG AT 33x12.5r15, with the wheels linked below. Would this work? I've done my best to research how rims are sized and looks good to me but I'm not sure. I only say time sensitive because tire kingdoms buy 2 get 2 ends tomorrow and that seems smart to do.
Pro Comp Steel Wheels Series 51 Wheel with Flat Black Finish (15x8"/6x5.5") https://www.amazon.com/dp/B00F0R6K34/ref=cm_sw_r_cp_api_IjcNxbCV8MJ8M
Thanks!!
I have 31" tires on my stock Xterra so I would think 33" with a 2" lift would work fine.
Yeah that I'm not too worried about, I'm more worried about sizing and measurements of rims working with those tires. But I saw the sticky and saw some people do the same or very similar so I should be good I think
Have fun cutting metal with that 3.75 BS.
I thought with a lower BS like that they'd stick out a little more which would give me more clearance?
What SRStaff is talking about is behind the front wheels. You'll have to remove the entire plastic piece cut some of the inner and bang the rest up if you want 33s. The 3.75 bs is best suited of going 3" sl. I have the procomp series 97s 15x8 3.75 bs, 33" MTs, 2" bl and pml.
Discussion Starter · #7 ·
Hmm okay. Did you do both lifts before tires? I was just going to do the BL, because if I read correctly the pml isn't gonna help my clearance? (I will be doing the pml soon anyhow. Was just gonna wait until after tires so I can focus on that.)
Also, what did you use to cut the metal?
Only thing that will give you fender/wheel well clearance is a BL. 3" SL or PML does nothing for clearance. The SL will compress all the way up as it did stock. With a 2" BL and 4.75" BS you are still cutting metal. 3.75" requires cutting even more metal. If you do not mind cutting you fenders all the way to your door; then you should be fine.
Discussion Starter · #11 ·
Yeah, I don't mind doing some cutting. Got my wheels in today, they're flat black look super nice. I'm excited to get it together
Another question, I'm interested in getting spacers just for the stance. Is that going to effect my clearance at all you figure? Don't know if something mainly aesthetic would be worth a lot more
1 - 11 of 11 Posts
