Yes in fact I believe it was on a thread here on CX that someone mentioned they had a vacuum leak until they had retightened the bolts. I'm trying to find it for you.
Just a question because I did not have any issues at all but I did see where some problems could arise. Did you use gaskets or the RTV sealant? Also can you see any pinched vacuum lines? This one might be a stretch but, do you have any worn vacuum lines that maybe when the spacer is in and stretching everything it is opening up some sort of a hole? I also don't know how much of a difference this really makes with our xterra's but did you unplug the battery before you installed it to "reset" the computer? Hopefully you can get it sorted out, it's definitely a mod thats worth doing.So I torqued the bolts down more and it runs good again. Then I proceeded to put the spacer back in and double checked the torque on the bolts and it won't stay started. I then took it back out again and runs just fine again. I'm completely stumped.
QUESTION:
Old thread from Zach here:
http://www.clubxterra.org/forums/showthread.php?t=24002&highlight=intake+manifold+spacer&page=9
Has anyone confirmed that these work with EGR? Looks like a few years ago a Frontier driver could not install the spacer due to the EGR tube being too short. Has this been installed on an Xterra with EGR? Do we know for certain that it will work?
If not...I will find out...maybe this weekend.
From what I understand and from what Zac has told me, is that the EGR tube on the Xterra is more forgiving than those on the Frontiers. I don't know if that is because of material, shape or location. My X doesn't have EGR so it wasn't an issue. Also, did PPEngingeering release that steering kit yet? They offered me to beta test for them but I had to turn it down due to work and not having time to go wheel it and give them real feedback. My steering is so sloppy its stupid. Shocks and steering rebuild are next up in my mods list. (Pretty sure I just hijacked my own thread haha)I haven't installed mine yet. My X is not driveable as I am still waiting on my steering kit build from PPEngineering.
I wanted to get my steering on so I could drive some before, so I can better compare after. I also plan on bypassing the coolant to the throttle body and manifolds and checking to see if port matching is a possibility to improve the flow.
Either way...I don't mind cutting my EGR, so I will make it fit!From what I understand and from what Zac has told me, is that the EGR tube on the Xterra is more forgiving than those on the Frontiers. I don't know if that is because of material, shape or location. My X doesn't have EGR so it wasn't an issue. Also, did PPEngingeering release that steering kit yet? They offered me to beta test for them but I had to turn it down due to work and not having time to go wheel it and give them real feedback. My steering is so sloppy its stupid. Shocks and steering rebuild are next up in my mods list. (Pretty sure I just hijacked my own thread haha)
Nice! Let us know how that steering kit turns out. They asked me about testing the heim tie-ends not that whole kit like you are doing but I like the idea of a more modular design and being able to swap out with stock if need be but if the price gets crazy then I may stick to just doing the grassroots link. Good luck with the IMS, I'm interested to see how (if there is any) port matching turns out.Either way...I don't mind cutting my EGR, so I will make it fit!
PP has not released the steering kit...they have had my parts for about 6 weeks now and are still developing. They are boxing my idler and pitman arms, which they have completed. They were having trouble sourcing a bearing that fit in the center link the way they want it to, so they are sending me an OEM center link with the boxed arms as a temporary measure to get my truck on the road while they decide which direction to go on the centerlink.
Their center link is a bit different from grass roots. They were trying to find a bearing that fit in the stock socket that the ball joint was in...where as grass roots cuts it off, and welds a steel sleeve in its place. They also welded up a double shear bracket on the center link itself (similar to how the king kong steering kit is from total chaos fabrication). This is different from how some people use grass roots center link and add double shear brackets on the idler and pitman arms. With their type of set up, the kit is more modular...a stock center link still can be substituted in if theirs breaks...and same with idler and pitman arms. If there were any failed part, you could replace it with a single stock component and not have to revert the entire system back to stock.
My arms and OEM center link should be here tomorrow...so hopefully I can get my truck driving around. When I get the full kit installed, I will be doing a full review. I may tackle the IMS and port matching this weekend too!
Rock on, Akuria! Great feedback. I am caught up in a drum brake re-build at the moment so won't be getting to the spacer for a while. I want to take some time with the spacer, inspect for port matching opportunities, and bypass the coolant to the throttle body and the upper intake plenum.oh and i do have the EGR system on my X and I had no issues with it.
