Some back story, I have a 2004 non supercharged 2-wheel drive xterra w 159k miles. A few months ago I was getting some really bad mpg and my SES came on, I got it scanned and my engine bay 02 sensors were tripped as well as the ones near the catalytic converter and a fuel level sensor that comes and goes?:
p0132 Air fuel ratio sensor 1 circuit high voltage
p0152 Air fuel ratio sensor 1 (Bank2) circuit high voltage
p0138 heated oxygen sensor 2 circuit high voltage
p0462 fuel level sensor circuit low input
The recommended part was engine wiring harness?
Well I did the trick where you would clean the ground strap washer and bolt for the engine bay's 02 sensors I had to actually relocate one of them as well as change the nut and washer because the original location was so badly rusted.
now I cant clear my codes as I dont have a scanner only a autozone readout but My SES turned off on it's own after about 200 miles of me doing that and has stayed off for about 160 miles after that but came back on and now I have p0430 catalyst system efficiency below threshold (bank 2) this is the only code with the previous still in memory
I assume that my 02 sensors are actually bad and the grounding wasn't an issue and me running lean for so long and putting up with the terrible gas mileage caused my cat to die OR I really did need to clear the codes so that my car can readjust itself to quit running lean. Is it true that the fuel level sensor can trip the cat's code, are there any work arounds? I will continue to do more research on this but I'm weary on buying a new cat. ANY incite is really appreciated!
