1 - 2 of 2 Posts
I have a leaking hose that I for the life of me can't find the name of or dimensions I found a website that called it the engine pipe to pipe assembly hose another website gave me the part number which is 14056-4S103 on that website it is called hose-water I really just want the dimensions so I could replace it.
Any help would be appreciated.
I'm assuming you have a first gen xterra (2000-2004) if thats the case then all the hoses should be 1/2 inch diameter if i remember correctly. however the hose on top of the thermostat housing is completely different and should be brought from nissan. just buy a few feet of 1/2 inch diameter hose, cut it to length and you should be fine.
1 - 2 of 2 Posts
