Car is a 2007 second Gen xterra.
So like the post says. My blower fan had slowly been losing options, one didn’t work when we bought it then two went then three. Finally the blower motor just died.
So replaced the resistor, and blower motor. Only to have the fan work on only 4. I plugged the old resistor in and it works on 3 and four. The dealer says he “tested” the new resistor and it works as it should.
Next step by pass the switch to rule that out. Unplugged the switch and bridged between pins 4 and the pins for associated fan levels 1-3. Nothing on the new resistor but the old one runs on three same as the switch.
Im of the conclusion the new resistor is bad but the dealership is not. Anything else I can try short of getting a resistor from somewhere else.
I’ve searched the forum enough to know it should be the resistor, all of the fuses are still intact so I’m kind of at a loss.
Thanks
Thanks
