I have a 2001 and for some reason my odomoter light will only read early cold morning if i bang on it and same goes for my fan speed for heat and ac. Just wondering if this can be repaired or if i should save my time riping the dash apart and just live with it.
I took the instrument panel out of my 2001 and changed all the bulbs to LEDs.
In the image below, looking at the back of the IP, there are 2 small gaps in the white plastic at the bottom. Just above the right one is the single bulb for the odometer.
76853
What LED lights did you use? I'm looking to do the same pretty soon.
