1 - 10 of 10 Posts
02 4x4 xterra s/e manual supercharged
New fuel pump, new fuel filter, new distributor cap and wires? Where do I look next? No check engine light but oil and battery light stay light when cracking with flashing ABS light?
03 XE A/T, SC coming soon
You should be able to check it without removing it. You’ll need a timing light to adjust your new one though
Discussion Starter · #6 ·
Do you know if there's a specific one needed for the supercharged version? Or if it's standard?
I just experienced this on my new to me '02 3.3 on a 250 mile trip. Turned out I got lucky with an honest mechanic that diagnosed it with bad fuel pump due to the well known hangers failure (or so he guessed). In anticipation of the needed parts he found after 4 or 5 tries to locate the parts for replacement. Luckily he had time due to a cancelled customer apptmt, to open the tank to check the pump, and found the pump, by previous owner or mechanic, had been installed improperly. He cancelled the incoming parts order and had me properly set up within an hour or 2. The fuel line hadn't been inserted all the way until it clicks. Supposed to jerk on it a couple times to be sure it is locked into the pump. Obviously they didn't check it.
Thank heaven I got a good referral on using this shop from a customer that lives in the area and received such excellent & honest service from Domestic Auto & Towing in Clyde, NC, 30 mins west of Asheville. Obviously I learned a valuable but obvious lesson in basic wrenching. In this situation, it was either the ignition= fire or fuel delivery = pump. He tested the fuel delivery first by disconnecting the hose/tube delivering the fuel air mix to the injector. Then on his signal, I turn the starter key as he sprays a tiny amount of fuel just enough to make the injector cough like it is starting. Of course that engine start only lasts a second or 2 but that tells you the ignition is good, so process of elimination says it is fuel delivery failure or likely the pump.
Good luck on your issue!
Good to see folks getting treated well! Good to see folks handing out kudos to folks like that as well.
Discussion Starter · #10 ·
Thank you everyone for all the help and suggestions problem solved it was a bad distributor well... the coil inside of it. the rotor still spun while cranking. I also replaced the fuel pump and fuel filter just because the X is almost 20 years old so i figured why not.
1 - 10 of 10 Posts
