1 - 17 of 17 Posts
Hi guys and girls,
Just doing my timing belt and just need some insight of removing this pain in the butt sprocket? like i didnt have a toough enough time getting the crankshaft pulley off! why even bother with m6 threads way to small and weak. anyways i have soaked the bastard in penetrant and wd-40. Whats your guy's tricks and tips. thanks
You need a 2 jaw puller to remove this, be careful don't stick any thing behind the gear is the oil pump and very delicate.
try renting a tool from you local parts store. i just did the heads on mine so that was one of the things i had to deal with. ended up renting a puller for a few bucks and then got my money back when i returned it.
Discussion Starter · #13 ·
Ya everything is out and I just can't see a puller getting on the back of hat gear does anyone have a pic with the puller on it?
Discussion Starter · #15 ·
Got it off by drilling two holes and tapping two holes with m6 bolts I had from the crank pully and came off with some good force
1 - 17 of 17 Posts
