I have a 2002 2wd xterra. Cranks but won't start. Acts like it wants to start as soon as you turn the key but won't, acts like it has no gas but has a full tank. When it first happened it started and was running real raggedy and I had no pressure on the fuel pedal as well but it stalled out and haven't been able to start it since. Any suggestions?
Like racer said...is your check engine light illuminated? Lack of fuel...could be a clogged filter. Electrical, distributor, spark plugs or plug wires...timing coulb be off...cripe, it could be an assortment of things.
I had the same issue with my 02. Check your fuel sending unit and fuel pump. There were factory issues with the sending unit connections corroding on the 2002s. There's a trap door under the passenger side back seat cushion. Should be able to see the connections after pulling the plate off. There's a tutorial on it somewhere on this site. It's not a super difficult DIY.
