2011 with about 76000 miles.
So, I am just trying to track this down. I get the smell of coolant while running and for a bit after.
I am not finding any obvious leaks, but I also do not have white smoke or any sort of codes.
To be fair, since I got the truck, I have always been able to smell it. Just maybe a bit more now.
Level does seem to gradually drop, but the coolant looks fine, so I don't think there is any sort of leak going into the tranny.
Back in december, I got sideswiped and it got repaired. Though I think the repair could have been better. The shop did not fill the fluid completely, so I had cold air at idle, which would warm up while driving. I have put more coolant in, and that cleared up.
It seems as though the smell may be stronger on the driver side, but that would be hard to back up.
Are there common leak points to look for? Is it possible that since the system was never properly bled, that the smell is coming from air in the system? Do the caps leak a bit? The truck does not overheat, temp gauge stays nice, even with some idling in the summer.
Just looking for a couple things to check out.
