1 - 1 of 1 Posts
So just got back home did my little routine checkout of the motor i usually do every couple weeks... Well i seen where my coolant and the reason i overheat after a long time... The hoses on the plenum. I seen coolant or what appeared to be coolant sitting below the distributor and puddling up underneath right under the plenum and running down the distributor. Thank god... Was getting tired of not knowing where my coolant was disapearing thinking it could be my headgasket. Well what hoses do i need to get for under the plenum and where? I mean i can order them all over but i wanna make sure i dont miss a hose. I want all under the plenum done and since this is problem the bolts on the plenum the head on one of them is stripped so it should be a super fun job. Plus its a perfect time to do the valve covers and maybe headgaskets just to do them although i doubt they leak. Better safe than sorry right?
1 - 1 of 1 Posts
