1 - 4 of 4 Posts
I have an 03 Xterra and the drains in the cup holders have clogged up somehow. Has anyone had this problem? If so does anyone know where the drain is located underneath the car? i would imagine there is a tube that sticks down somewhere. Any help is greatly appreciated.
I have a 2003, but my cup holders have factory liners in them. If I spill or there's condensation I jsut pull them out and dump em. I'm not sure that Nissan would have bothered with a drain line and considering that it;s directly over the transmission you will have extremely limited access from under the vehicle. You may want to try removing the console to see what you can see.
Personally, I'd recommend getting a couple of rubber liners. They're not super cheap, but not too expensive either. You can fine em for about$30 for a pair.
Here's an example.
i have the liners but while i was cleaning the car I spilled a cup of water and it did not drain out like it has in the past. I fear removing the console is my only way out.
1 - 4 of 4 Posts
