1 - 12 of 12 Posts
My xterra threw this code and now is in limp mode I changed the fuel pump alrdy and next going do the timing chain and new radiator stuff also has anyone ever came across this before in there xterra mine is a 2008 xterra s model with the 4.0 I'm it any ideas what could it be I going to replace all injectors after timing and everything I got more money for cheap parts than I do for labor any ideas ty very much glad to be part of a group I'm clif btw
Start by checking the two little grounds on the top then move on to the other ground connections. Without looking the code up, I can tell you that it’s not common and if I remember correctly it implies an open ground for the 5v sensor circuit but again I didn’t look it up
Ty I will try to find the other grounds I know the ones your talking about that's by the vvt timing sylanoids it's it those I slrdy cleaned those ty for you guys trying to help me too btw
Discussion Starter · #7 ·
Can you guys look it up and plz help me find out why my x won't rev up past 2k roms and I can drive it again ty so much
I've changed the fuel pump the battery the timing chains was my next step and ordered all new sensors and new radiator BCS of the mod thingy I hope to be able after all this to just drive my x long time ty guys again try help me
I can look it up when I get to work. I’ve only seen this code once before if I remember i think it was on a Titan. Some other shop had done a bunch of work and there was a ground issue on the sensor circuit when I was done. I don’t know if I ever found the issue I think I just tied a ground near the ecm because they didn’t want to pay. I’m sure there was a ground eyelet not secured or a loose ground bolt but I never saw the car again. I think I measured the power steering pressure sensor ground wire and found 5v which means open ground. This was a long time ago
Discussion Starter · #9 ·
Ty I'll check that
You really don't need to keep quoting yourself. The thread keeps all of the posts in order. When I see a quote, I figure that the reply is to another member.
A bad TPS?
1 - 12 of 12 Posts
