I just replaced the clutch hydraulic line (rubber hose that connect the steel line from the master cylinder to the operating cylinder). Removing the hose drained all of the fluid. After installing the new hose and refilling the reservoir the clutch pedal stays on the floor. I have to pull it up and then push back down, no resistance. If I open the bleeder valve and have someone depress the pedal fluid comes out. If I open the bleeder and work the operating cylinder same thing but the system never seems to pressurize. I'm at a total loss. Any ideas?, why am I not getting pressure? I've filled the reservoir twice now so fluid moves through the system. Picture is of the hose that was replaced.
2004 3.3L 4X4 126K.
2004 3.3L 4X4 126K.
