1 - 6 of 6 Posts
None of my cigarette lighters are working (the lower dash, the center console, or the rear hatch). I've triple-checked my fuses, (1-they all look good, 2-when placed into other fuse slots of the same amperage everything works, and 3-when spare fuses are put into the three fuse areas for cigarette lighters they continue to not work). I've checked, replaced, etc. the 20 Amp under the hood and both 15 Amps in the dash. Nothing is making any of these lighters turn back on. I'm in desperate need of ideas of what else to even look at.
For what it is worth, the other day I did mess with the center console and the wires back there. That is definitely when this all went wrong, but I figured I just shorted a fuse. It seems that's not the case, but I can't figure what else I could have done here as all the wires are intact, the connections are good, etc. Any and all ideas are welcome. Thanks!
where where you messing with wires behind the center console? it sounds like you may have some crossed or may have inadvertently pulled a few loose, i would check the wires in the area you were messing with. iof someone has wiring schematics they can share with the OP that would be handy, having a hard time finding them.
Discussion Starter · #6 ·
I was afraid that might be the answer. I was messing with the wires near the radio and aux port (just above the dash cigarette lighter) and removed all of the console cover just above it (where the A/C controls are). So, entirely possible I may have pulled something loose, but without schematics I'm kind of flying blind as to where the problems could even possibly be. Thanks, and if anyone has the wiring schematics, that would be of BIG help.
1 - 6 of 6 Posts
