Hey guys. I'm having a little issue with my X. My check engine light does not work. I purchased it in Oct '11 and it has never worked. I scanned it with my scan tool when I got it and no codes were stored. However I checked it again a few weeks ago and now it has a code. I've already fixed what's causing the code. The check engine light doesn't illuminate when I start it up either. Could it be something simple like an ECU ground or do I need to replace the cluster?
My X is a 2002 2wd 3.3 5 speed with 115K.
Any help is much appreciated.
Thanks in advance.
Thanks in advance.
