I know this is not the first of these threads on this site.
I can't figure this out...
Simple change of timing belt and components. Used a Gates belt from Napa with the timing marks (can't really screw that up can you?).
Put it all back together, wouldn't start. Engine cranks just fine...over and over and over.
Tore it all back down, figuring I must have messed up the timing marks. Found all the timing marks appear to be in the right places. T crank pulley mark lines up with the mark that the previous owner made on the oil pump housing. The "dimples" in the upper REAR timing cover match up where it was when I removed the belt the first time.
The RH cam gear (passenger) mark goes (pretty much) dead on with the dimple on the upper rear timing cover. The LH cam gear is off about 1/2 tooth still, as it was when I pulled it apart the very first time. Annoying, but I assume this is correct. It's off to the CW direction (the mark on the cam gear is CW 1/2 tooth past the upper rear timing cover dimple).
I checked for spark...pulled a plug and wire and left it out against something metal on the engine while cranking the starter. Yep, got spark.
I checked for fuel...I can hear the pump prime when I turn on the key...and I pulled the return line from the fuel rail and turned turned on the key...yep, there is fuel.
There are NO related codes being recorded by the ECU, verified with an OBDII scanner tool. There is a code for something related to the idle air control valve. This is new. Wasn't there before I pulled the timing belt out. Could be a just didn't reconnect a sensor when I tried to start it??
Only thing left I can think of is to check for compression. Maybe the belt is still off, somehow.
OR, maybe it jumps a tooth after trying to start it the first time?? Doubt it, since the cam gears and crank pulley still line up properly (though you can't check the lines on the belt anymore - they don't line up after the first time turning the crank manually to adjust tension).
Is it possible the camshaft position sensor in the distributor can go bad, WITHOUT throwing a code? What about the crankshaft position sensor?
Anything I'm missing? Any help/advice would be appreciated!!
Thanks!!!
Thanks!!!
