I had my check engine light came on this morning and I had the code spoiled I came up with a knock sensor code and a TPS sensor code. I assumed they knock sensor code was from me replacing my distributor and not immediately setting the timing. Also at the time I was not thinking about it but I had to remove the TPS sensor to get access to the distributor mounting bold and I am Not sure if I put it back in the same place. Anyway after having the codes pulled I drove 40 miles without any issues. let it sit for a few hours fired it up and went to drive home made it 5 miles down the road and ended up stranded. It started to die and would only run if I took my foot off the gas. I tryed to clear the ecu hoping it would get me home but no change. I had to be towed home. It starTed several times without issue while waiting for the trailer but when I got home it won't start at all.
Tps sensor? Whatcha think
