That is what we are here for bro.
Mine was smelling bad, too. My valve cover itself was warped, letting oil drip down between it and the firewall, onto the exhaust.I noticed a burning smell (oil I think) coming from my X recently... when I'm in park or stopped. It's a 2002 2wd and I know I need a new alternator belt but I don't think that's the cause. My A/C has been broken since 2009 (I know... I've let this go way too long... but I just recharge it in the summer) so it's probably a leak. But it's winter now and I have only turned the heat on a few times. Does anyone know what they think it could be? I read about bad head gasket but really not sure. Should I do a leak test by draining the antifreeze and adding water and dye? I don't mind my A/C not working still but I don't want this problem to blow up into a huge one. Any ideas? Pricing to have these fixed recommended as well. Thanks!
I had Nissan dealership put both valve cover gaskets on last week. $561I think I read gaskets are pretty pricey to have fixed?
Drivers side gasket is the only reason i did let the nissan dealer change mine. Changed both sides = $561Valve cover gaskets? It depends which side, passenger side is very easy, driver side not so much.
