Passenger brake light is out. Also, the passenger side of the third brake light is out. The turn signal, taillights, and drivers sie all work. A quick search said it might be the brake light switch. Can someone verify? (i got conflicting results when I googled it so...) Also, I gadget even started looking but I imagine that it is a fairly straightforward install but correct me if I'm wrong.
Thanks!
Discussion Starter · #2 ·
After more research... Not necessarily specific to xterra though, I'm thinking that if the switch was bad, the entire third brake light would be out (although, I could be wrong, correct me if so). So now I'm guessing I have two problems, a bulb is out (easy), AND a faulty third brake light. Can I replace those bulbs too or do I have to replace the unit?
Thanks!
