I want to lift my X here in the near future but i'm not sure if its worth doing the BL or the SL. Is there pros and cons to both or is it just a straight preference thing?
You are currently running ~30" tires, 29.6" specifically. You can run up to 32" tires without having to do a body lift, although you may rub a little at full turn (I rub a bit with 31.6" tires).I need to find some new tires, i run 265/70/15's im not sure how much bigger i can get or want to go right now, but if i do want to go bigger and need the BL i would do it. I'm only asking now cause i'm banking on a tax return and need to spend it on something...
Thanks man i was trying to do all the conversions and math last night to figure that out, but i hate math. so thank you!You are currently running ~30" tires, 29.6" specifically. You can run up to 32" tires without having to do a body lift, although you may rub a little at full turn (I rub a bit with 31.6" tires).
33" rubber will require a body lift and/or significant trimming up front.
i love how cut and dry your response are in threads, thanks. i'll start trying to piece things together. Like i said at the end of the year is when i'll probably buy tires.Here is the thing... Form a plan.. If you may head down the way of lifting I'd go 32s or 33" tires.. Tires are the best performance mod you can do.. Every one that buys smaller tires regret it quick.. Nether the BL or PML are very hard.. A BL can be pieced together for 70$
Takes about 4 hours to do.. The PML can be done in 2 hours..
Nether hurt your Xterra at all.
Sorry about how dry that was.. When Im on my phone I feel sorta rushed to answer these so I may come off a bit dryi love how cut and dry your response are in threads, thanks. i'll start trying to piece things together. Like i said at the end of the year is when i'll probably buy tires.
No dont worry about it, i appreciate the cut dry this is how you do it answer. Makes understanding easier.Sorry about how dry that was.. When Im on my phone I feel sorta rushed to answer these so I may come off a bit dry![]()
Yea! I want to go w/ 35s as soon as I take the plates off of BlueX and trailer her.Really Blue? 35s? Damn it I need to finish my SL LOL
