1 - 2 of 2 Posts
I changed my alternator and now I have belts squealing, replaced belts 8 months ago, belts are tight.
2001 Xterra 4WD Auto 3.3L V6
They can also be too tight.
Or the tensioner(s) could be squeaking.
Or a pulley is not aligned correctly.
Squirt water on the grooved side of the belt. (Not the flat side.) If the sound goes away, then you probably have a misaligned pulley.
If the sound gets louder, then your belt is too loose.
1 - 2 of 2 Posts
