I have a 2002 Xterra SE s/c with 152,000 miles on it. About a month ago it developed a very minor knock which was only noticeable at idle. The knock slowly got worse each day I drove it until one day it got really bad. It was very noticeable when driving, the truck would buck and snort, had no power and gas mileage went way down. The CEL threw 4 codes- 2 for Random/ Multiple Cylinder Misfire, and 2 for Knock Sensor.
About 2 weeks ago I replaced the knock sensor , which by the way is a real PITA, as it is hidden on top of block under the intake manifold. While I was in there, I also installed new NGK Platinum plugs and wires, new fuel filter, and cleaned the MAF sensor. The cap and rotor were replaced last winter, probably about 20,000 miles ago, and still looked fairly good. Everything else I took apart looked really good. I was impressed that the fuel injectors looked brand new. I cleaned everything up and put it all back together with new gaskets.
The truck ran extremely well. Probably as good or better than when I bought it with 3000 miles on it. It ran good up until yesterday when it started to knock exactly like it did before. In the 2 weeks since the repair work I drove about 600 miles running premium fuel through it.
Anyone have any ideas? Could the knock sensor I put in have been defective? Is there anything else I should check?
