1 - 1 of 1 Posts
I am about to order my ARB locker for my 2003 2WD xterra it will be used for light to medium trails (no real mud) but I have two question I hope I can get some help with.
The axle code is CA48 so I was wondering if this axle is weak as I cant find any good info on this diff. I wonder if it would make sense to look at getting a stronger diff (if required) before ordering the ARB?
Also I was wondering if it would be best to install the ARB compressor CKMA12 in the engine bay so I can keep the noise out out cab and easy access to use it to pump up tires. Is there any drawbacks to install it there other that running a hose to the rear diff? What do must of you guys do?
Thanks
1 - 1 of 1 Posts
