1 - 7 of 7 Posts
2001 SE 4x4
I've been following steps from a post that explains removal, but I didn't get too far. I can't get the knob for transfer case off. It looks like 2 pieces; knob and black sleeve that are fused together or something. When I try counter-clockwise to twist it, the knob and sleeve both turn a bit but nothing loosens. Amy idea?
You need to measure the vehicle ride height at the front. I measured the height of the wheelwell at the center of the wheel. You probably won't get the keys on the torsion bars back exactly where they were on the bars so going by the length of the bolt won't work. Just make sure you adjust the height then drive it around to settle the suspension and re-measure and adjust as necessary.
Discussion Starter · #7 ·
ok, I'm going to do this the right way which is what I should've done to begin with. I'm going to replace the torsion bar adjustment anchors and other parts on either end of the bars. I've been looking for 4x4 clubs and other resources. Do you have any place I should go for these replacement parts (bone yards out of the winter & salty road states) to suggest?
1 - 7 of 7 Posts
