Is your engine Supercharged?Any one know where to find a complete diagram on how to do a Knock Sensor relocation, and the parts needed? thanks, 2002 Xterra 3.3
No sir, i dont think so atleast. how would i know? Also, i removed the air filter box completly, the two left side hoses, the right side resonator(which is just hanging, bolt mount are broken, and the "2 wire" clamp the hold it to the air intake is cracked right in between the wires(is this a leak?)) and the bottom part of the air filter box. I cant seem to get the plastic pipe in the back thats up against the driver side fender to reconect. that box is loose. Now my xterra is running worse, when i shut it off, it shakes. I also adjusted the throttle body cables (cause there was slack in the gas pedal). Now the RPMS run about 1200, when they were 750-800RPM. plz helpIs your engine Supercharged?
So i could use these parts in this video for my 2002 Nissan Xterra 3.3 NA? and is it recommended to relocate these things, ive heard different stories.To those interested in doing this relocation here's an awesome video to show how. Beats the hell out of spending 8 hours to get it done.
Can you by chance post some pics on where the wires are located?We just did the relocation and followed the video to the T on our 2002 Xterra. The wires matched up perfectly but I thought there were 2 wires to spliced in the loom. Turns out there is one wire for power and some fine metal strands that are the negative connection. We just twisted the bunch of strands together and connected them to the negative wire on the new harness. Bought the 99 Maxima harness and sensor listed in this thread, spliced the new harness in and installed the new sensor on top of the intake. Still had the knock sensor code come back after I cleared it. A lot of times Nissan/Infiniti vehicles don't play nice with aftermarket sensors so I bought an OEM knock sensor and swapped it with the generic one. Cleared the code again and it came right back on a short drive.
I cleared it one more time and we're going to put some miles on the truck hoping that the computer just needs time to see that it's working correctly and won't throw the code again. If not and the problem persists then the relocation didn't work for us, FML. The only other thing I can think of that's causing the problem is a faulty OEM harness so I'm in the process of trying to find out where it originates before it heads down into the depths of the motor. I'm not looking forward to tearing the top of the motor down to replace a stupid $40 sensor, that'll suck....
Just follow the video above, it's super easy to find them. On our 3.3 NA the wires are just to the left of the intake in a small rubber sheath. Be careful cutting into the sheath so you don't slice into the power wire and make sure you disconnect the battery before you do any work on the motor.Can you by chance post some pics on where the wires are located?
