1 - 9 of 9 Posts
Hey guys.. my new to me that my hubby bought last month is acting up! It's the 03 non supercharged,decided to change my air filter and now it's spitting and sputtering i have to put it in nuetral to keep engine revved not to mention chk engine light came on again after getting gas.(cleared it then when getting gas it happened again)i already replaced gas cap since dealer said that's probably the problem when he read code.when light came on it was still driving fine until I replaced the air filter. .new plugs were put in also.im thinking a sensor?? Any one with ideas?thx a bunch!
sent from AngelicOne and her new X;)
It's not an oiled air filter element is it? Oiled filters really shouldn't be used on a car with a maf. The oil can come off the filter and dirty the maf.
So like said above, get some maf cleaner and give it a cleaning.
That probable not what happen when you removed the old one you knocked some dirt off it and it got on the MAP which is right next to the filter. When ever you remove the filter you should shop vac the box and clean out with damp rag and dont let any dirt from old filter fall off.
Discussion Starter · #6 ·
Yes! That's probably what happened.as my other truck was simple and had no issues guess the xterra is a bit different.ill look up where it is and clean it up good hopefully this will do the trick.i already have to take to garage for a oil leak near the back drivers side and another by the top belt pulley..glad it's still under warranty! Thx guys!
1 - 9 of 9 Posts
