What antifreeze is right for your Xterra? Why?
First off Nissan recomends a silicate free HOAT antifreeze, with a phosphate additive to protect their cooling systems from corrosion and rust.
In order to keep Nissan from draining your wallet, there are other brands out there that work.
Zerex makes one called Asian Vehicle antifreeze/coolant.
Why is this so important?
First off there are many types of antifreeze and using the incorrect one can be disasterous to the antifreeze/coolant containing parts.
Some are not compatible and some have no long lasting corrosion protection.
Some actually cause electrolosis in multi metal engines (Like the Xterra).
Nissan makes one with their brand name on it for about $20 a gallon (full strength)
The Zerex is designed for us too.
It is 5 year 150,000 mile guarantee
Compatible for Asian engines
Silicate free with phosphate HOAT chemistry
Protects against corrosion and rust (important for iron/alluminum engines)
and this one is premixed, so you just pour it in.
I hope this clears up, why you need to use the correct type antifreeze/coolant!
Please note, you can buy this in full strength also and then add your own distilled water to it!
