What’s the purpose of this?
So I can go off roading and not submerge the alternator into water I do plan to put snorkel kit on as wellWhat’s the purpose of this?
I’ve got a 02 xe v6 auto 4x4As Blackberry mentioned. If you plan to do anything deep water you're going to need to replace the crank driven fan with an electric set up that has a switch to shut it off during submersion. The resistance provided by the water will cause the mechanical fan to bend into your radiator and ruin your day.
Alternators get wet all the time just by driving in the rain. Granted, they don't get submerged, but I'd also worry more about relocating the ECU. You don't list which year your X is, but on the gen1, the ECU is located on the hump under the radio console. That's about 4"-6" higher than the transmission. If you are going in water that's deep enough to flood your engine bay, then you're going in water that's deep enough to flood the ECU.
This is why snorkels are stupidAs Blackberry mentioned. If you plan to do anything deep water you're going to need to replace the crank driven fan with an electric set up that has a switch to shut it off during submersion. The resistance provided by the water will cause the mechanical fan to bend into your radiator and ruin your day.
That was my point. 98.6% of people would never need a snorkel. I know I don’t because I hat water in my floor.I disagree. Snorkels do provide a higher intake site,vs the stock system that sucks air in from under the front fender. While the water may not be sucked up the stock intake (or may), it will block air flow, which could result in a stalled engine. Likewise, installing a CAI up at the same level of the engine could still result in splashed water getting into the intake.
Granted, they aren't something needed by most owners, as most will probably never go through deep enough water to cause these issues, but there is a time and a place for them. It all comes down to what you're actually doing with the vehicle. And besides, aesthetically, beauty is in the eye of the owner.
