1 - 2 of 2 Posts
01 xterra 3.3L manual trans 4x4.
So I have been having an odd issue with my X. I have a pinhole leak in my radiator and when the water level gets to a certain level, the ac quits blowing cold. At said point I would add water and all would be good. Recently the ac has quit blowing cold air all together. The water is full and I put a can of refrigerant in it also. Any ideas?
Thanks
Is the compressor engaged still when it's not blowing cold? If you are low on pressure it will not engage. If it's overfilled it will cycle one and off.
1 - 2 of 2 Posts
