1 - 2 of 2 Posts
Ok. need a little help here.
Taking apart, I totally get. PB BLAST the shit out of everything. Putting back together the right way, is completely different.
What kinds of grease, lubricants, gasket sealers, do ya'll suggest for the following:
Full 3" SL lift from AC (Articular package)
Full 2" BL lift from AC
Doug Thorley headers (already have the metal gasket, exhaust stud nuts, etc)
Also, any suggestions for the TRA's ? and do i need any for the Torsion Bars ?
Never-seeze any fasteners for exhaust and on the torsion bar splines. I don't think I put anything like loctite on the body lift bolts because you should re-torque them after you drive it around a bit so if any of them move it breaks the loctite. You could put never-seeze on the threads of the suspension parts if they are using self-locking nuts but then your torque values change if you are wet torquing so I wouldn't bother.
1 - 2 of 2 Posts
