1 - 1 of 1 Posts
I just replaced the water pump in my 2008 X terror yesterday. When I did it I also replaced the timing chain tension or. When I put it all back together it seems like the timing is off. The truck is less powerful than it was before period is it possible I turned the crank shaft too much when replacing the tension or and through the timing off. If so how can I fix it question
1 - 1 of 1 Posts
