Awesome bossx had it out in 3 minutes (took my time)! Can see visually that its burnt on the first 3 terminals.
Thanks for the video big help. Hopefully my local Nissan dealer has the part or just might do the Amazon route.
Big thx
Aaron
no prob at all it was my pleasure. Even though this is the part I want to take credit for this I simply can't. The reason that I knew about this is that I was looking at one Xterra with this exact problem before I bought mine and researched it extensively to see what I would have to drop to fix it. Guess where I did my research? Right here, and this is why I joined this site, the collective minds in this place simply blow away any single mechanic or the professionals at Nissan. I joined this site and have never looked back, so many friendly people with a ton of golden advice that has already saved me hundreds if not thousands.
On another note, I would go with the Nissan part, you don't have to wait, in case you get a faulty one you can just swap it with your Nissan dealer and not deal with the return headache plus you will probably only save about $10 or so and have to wait. This is not that expensive of a part, but then again I could be wrong. See what Nissan quotes you, I think they range from mid 20's to 40 or so depending where you go. Check that vs Amazon.
btw, I would trust Dejablue's opinion as a solid one for any help, he seems to be the wise man that seems to be on spot most with any issue I have seen him comment on.
