Hello,
I have an 04 V6 with 4WD and manual transmission. The trans is driving me nuts because it's so uncooperative. I've driven plenty of stick shift vehicles before, ranging from my 89 Mustang, to VWs, to a diesel box truck with a dog leg. However, this thing drives me batty. It's the only vehicle I've ever driven that requires double clutching.
No joke, the only way to get through 1st and 2nd is to double clutch. I know 1st isn't synchronized (because Nissan was too cheap) but 2nd is supposed to be. However, it absolutely won't have it. The only way to get in is to release the clutch, blip the gas, then quick put the clutch in and get the shifter in at just the right time. The same goes for downshifting in ANY gear. If you don't double clutch, there's no way the shifter's going into gear. It doesn't grind, it just feels like there's a wall between you and the gear. No matter how hard you press, it won't move. Double clutch, and it slides right in. I don't get it.
One more thing, when it's cold, it's hard to get it OUT of first. If I put in the clutch, the RPMS stay up, and it keeps going. I have to really pull it to get it out, at which point the vehicle jerks. I have to then double clutch into 2nd. That goes away when it warms up.
Christ, I feel like I'm driving a freakin Peterbilt here. Took it to a general garage and they couldn't figure it out. Kinda ticked me off.
Anyone have any ideas? Anyone run into this kinda thing before? Also, what is the make and model of this transmission? That way I know to steer clear of anything else that uses this dreadful gearbox. I assume it was farmed out to a transmission company, like how Ford used Borg-Warner for their transmissions?
Any help you could provide would be appreciated.
Thanks a lot,
Jon
Thanks a lot,
Jon
