I was in the process of installing a remote start system in my 2003 Xterra and I went to start my car to probe for a wire and the car cranks but will not turn over. I have not yet connected any parts of the remote starter, I've just braided the wires into the ignition harness. The only thing I've really done was disconnect the pigtail to the harness and then reconnect it. I haven't cut any wires or even disconnected the battery. Any help would be greatly appreciated!
Daniel
Here's the best way I know of to get an Xterra to turn over.....
Hope that helps.
:D
Put everything back to the way it was and then try to start.
It started before?
Then you messed with it?
Then if that does not work, just for the hell of it do disconnect the battery for a short time.
Maybe something needs to reset?
Discussion Starter #5
thank you all for the help, I got it to turn over finally. I think somehow the engine just got flooded by me laying on the gas pedal or something. after sitting for a while, it finally started but sounded like it was hiccuping a little, but after several starts all was fine.
