I have a 2003 Xterra 2wd 3.3L 6 cyc non-supercharged. The smaller all aluminum (no flexible rubber) hose/tube that goes from the condenser to the firewall cracked at the condenser inlet and needs to be replaced. I need some tips on what to take off to accomplish this and if there are any other parts I should replace while replacing this part. This is generally an L shaped tube that connects to the condenser on the driver’s side, crosses to the passenger side on top of the condenser then snakes back to the firewall on the passenger side.
Thanks in advance for any assistance you can provide,
Nolan
