Hello,
I have been working on this car for awhile and I'm stumped as to what is wrong. In the last few months I have installed the following on this motor:
1.New timing belt, water pump, and tensioner.
2. New proper Injectors
3.plugs, wires, cap and rotor. Did not replace distributor.
4. Rebuilt the cone on the supercharger.
Everything was running well for about 2 weeks when it suddenly started running really rough. Brought it home and saw raw gas being sprayed from a crack in the driver exhaust manifold. More gas dripping from the tailpipe. Pulled all the plugs and they look good. With plugs out I turned to on position to see if the injectors were open, but could not see anything. How can one test a distributor? I looked at it with the cap and rotor off to see something obvious but nothing of note.
Thank you for the help.
Tyler
Tyler
