1 - 2 of 2 Posts
4wd
3.3L V6
After 320K miles I finally had to swap the lower control arms on my 2001 Xterra.
The bolts are corrosion welded to the bushing inner liners, naturally.
A couple threads I've come across mentioned an OTC tool for driving in the new bushings.
Is this the correct tool:
https://www.amazon.com/gp/aw/d/B000...oint+press&dpPl=1&dpID=41iCGEQTeFL&ref=plSrch
If not, does anyone have a link to the correct tool?
Thanks,
Q
I have a harbor freight ball joint press ive used for bushings.. and it works. fine.
Im sure the OTC one will work better.
My OTC on car hub bearing tool is the shiz nit
1 - 2 of 2 Posts
