Factory timing procedures and settings can be found in the EC section here:looking for a factory timing check proceedure for a 2000 nissan xterra with 3.3l v6.the only info on sticker under hood is set to 15 deg btc
I don't know if it's different for the 2000, but it is different for the 2.4l. Download the manual, then use your browser's "find" feature to search the document for the keyword "timing."are the settings different for the 2000?the sticker under hood says 15
20 degrees plus/minus 2 degrees BTDC for the 2001 2.4l.I don't know if it's different for the 2000, but it is different for the 2.4l. Download the manual, then use your browser's "find" feature to search the document for the keyword "timing."are the settings different for the 2000?the sticker under hood says 15
PS: the manual does say to disconnect the throttle position sensor harness connector.looking for a factory timing check proceedure for a 2000 nissan xterra with 3.3l v6.the only info on sticker under hood is set to 15 deg btc
