1 - 4 of 4 Posts
most components have been replaced. Will not restart after it is warm, let it cool off completely then starts right up.no codes, all have been cleared, and items replaced.although it will start when you jump it off or undo negative for about 4 minutes. Any ideas, Thanks
Thanks for trying to help. Yea I have replaced dist, crank sensor.fuel pump.What do you all think about the temperature sending unit to the computer may be bad. I do not know which is which. They have two.I assume you check it with a ohm meter
1 - 4 of 4 Posts
