Hey and welcome. So I was going to initially say clogged exhaust/cats. While i didn't have an issue like this, my cats, all four of them on the xterra, were destroyed and clogged and rattling inside. Since replacing the two that are part of the exhaust manifolds, and eliminating the secondary ones that are after the o2 sensors, the throttle feel and responsiveness of the engine is immensely improved! I've had it for 5,000 miles and just assumed it was supposed to run like it could barely breathe. And also, because you've had some issues with o2 sensors it is likely a possibility that bad o2 sensors have been messing with fuel trims and blowing those cats out.
The other issue that is actually common is that distributor but you seem to have that all checked out. You're right around the mileage known to have that bearing break apart and wallah, it had!
It does seem like a strange situation though because metals expand when warm, so if anything, they should be closing potential air leaks as is warms up.
I wish you luck and would put some money on the exhaust being the issue. Let us know!
