I bought a very well maintained and well documented (so I KNEW it was well maintained) 2000 Nissan Xterra with about 190k miles on it about 3 months ago from a guy I worked with in California. Some shady mechanic told the poor guy it had a blown head gasket when all it needed was a coolant flush and to be burped properly. I offered to return the car upon this discovery for my $500 and the cost of my minor repairs (replaced some plastic headlights burping ect. you know the right thing to do he was a fellow soldier after all) but he was true to his word and had already gotten another vehicle well the car got me from cali to Illinois without a hitch but once I got home It blew a head gasket on the highway (irony is a jealous b**** right?) so I nursed her a mile back home and pulled her into the garage. Ive never worked a car (unless you count the mechanical rubix cube my saab was) but I've been restoring old motorcycles for quite a while now and have a knack for these things so I opened her up and have been working my way to replacing all the gaskets. I've gotten both heads off and pretty much everything else that is remotely near them except the lower engine portion and transmission. The heads are good (thank god) and don't need to be machined I obviously plan to replace all the gaskets I'm also going to replace all the cooling system tubes and the radiator seemed a bit awful so I plan to replace that to. Both exhaust manifolds are cracking (which seems to be a common issue) so i'm replacing those too I've replaced the dreaded knock sensor and I've replaced all the belts. The water pump and thermostat are new and all parts appear to be phenomenal working order upon inspection after cleaning that god awful oil coolant mix off of everything only strange thing I found was the top end of a wire cleaning brush lodged in on of the coolant pipes (shady mechanic strikes again?) My question (if you made it this far into my essay) is there anything else I should replace while I'm down here? oh and shout out to this guy https://www.youtube.com/watch?v=WfULyYKOhMk made disassembly with between him and the guide a cake walk.
