1 - 6 of 6 Posts
Hi guys,
so I have a 2000 Xterra 4wd with 175K miles. I just bought it a few months ago so know very little about the history of this vehicle. Troubles started when it cot cold here (not below freezing). Vehicle would go dead after start when I put it in drive or reverse, once the motor warmed up it would drive fine. This happened for 10 days or so. THEN, just as I am about to change the tranny fluid, I am driving around abut 5 miles and the tranny starts slipping. It will drive for a mile or so, then slip completely, no matter what gear. If I let the car sit for 15 minutes or so, it will drive again, another mile or so, and again, start slipping as before.
SO I drained the fluid from the pan, its dark, brown... but there isn't any water in it. So I added new fluid (about 5 qts), same issue. Drove for about a mile, then full slip again. Anyone seen this before, or can give me a direction on what to check next?
Its dead clutch packs are burned up ,look for a donner same year. Don't rebuild you will never be happy.
Thats bad news. I have an 01 sitting beside it I could pull and replace with. Any difference between 2000 and 2001?
You may have to change the ECM also.
Check both flywheels close before reinstall there is mid year change on 2001
1 - 6 of 6 Posts
