1 - 20 of 20 Posts
Has anyone ever installed these? I'm wandering if I have to remove outer sleaves or just the inner rubber of the old ones. Is there a loaner tool I can get to press out the old bushings? Any pictures or how to diys would be very helpful.
Front lower:
Rear lower:
03 XE A/T, SC coming soon
The entire bushing will need to be removed. I usually use an air hammer or saw to cut one side of the outer sleeve and then peel the bushing inwards
so should i use a haxsaw to cut the sleeve? and whats the best way to get the rubber out? i have no choice but to replace bushings because i have to cut the bolt on both sides to get it out. gotta love that northern rust! I've already removed the torsion bar.
Discussion Starter #4
I also have brand new lower control arms to go back in. will i have to do the same thing with the front bushings on the new control arms or can they be pressed out or hammered out with a socket slightly smaller?
Shop press is the preferred method.
There should be one bushing on the arm and one on the frame. The frame one is the one I’m assuming the listing is for. I’d use a sawzall to cut the outer sleeve after removing as much of the rubber as possible
Discussion Starter #9
heat up the metal to melt it out? any suggestions on some sawsall blades for the bolts? im eating through metal blades trying to cut the hardened steel bolts.
Those bolts shouldn’t be hardened. Any metal blade should do. I feel like I use the torch
Discussion Starter #11
hey you guys are awesome! thanks for all the help. I'm still waiting on parts but when it is completed I will post up some pics with the new off road tires and the lift.
Harbor Freight investment in a decent press and some blocks it will come in handy for a lot of suspension bushings
Discussion Starter #13
Just wanted to verify. I did have to remove the sleaves with the old torch and hacksaw method in order to install these bushings. I should have it finished by the end of next week. I will post pics when I'm done. I have my tires on order so should be installed next week.
Yokohama Geolander X-AT
265/75r16 Load range E
76104
Discussion Starter #14
So far so good on the overhaul I still have to finish the driver side. Here is my progress so far.
Passenger side complete.
76145
New urethane bushings in lower control arms.
76148
Steering linkage in.
76146
76147
Drivers side almost disassembled. I still have to cut the bolts for the control arms and cut out the sleeves for the bushings. Then I can reassemble everything and set ride height. Then it's off to the shop for alignment! Woohoo!!!!
76149
I need your address, and to have you park in a dark alley... ;)
Discussion Starter #18
Drivers side down to the frame. Now just gotta replace bushings with urethane bushings and reassemble then repack bearings set ride height and get it aligned.
76150
Discussion Starter #19
Well hear we go folks! The finished product! Got about 2000 miles on the new tires and suspension. Rides soooooo good and the tires are great!
Before:
76300
After:
76299
Discussion Starter #20
I purposely set it a little higher in the back for towing my camper.
76301
Still sits about 1/2 inch higher in the rear with the camper hooked up. Tows great down the road!
1 - 20 of 20 Posts
